so, i swapped in the new 6.2 and abandoned the 6.5 to the garage floor last winter.
i run the 6.2 in the first 5 k or so on straight diesel so i could get a solid baseline before i started mixing oil in the fuel supply. i did run oil mix in the cold for short term testing also as a baseline
it was a great engine...no real power increase over the extremely well worn 6.5, but it started excellent in the cold with no block heater and in the hot it started great as well, where the 6.5 does not like to start when its hot out after its been run hard.
work was bad this year.....again.
so i did not have much money to work with, when i started back to work my daughter was using the truck because i could not afford to plate the bronco and fuel it up, i had her running this ranger on 100% wmo for her needs as she did not have time for a job. i pushed her not to work because she was leaving for boot camp in aug and several short trips out of state were on the agenda and she had just graduated.....she would not drive my rig pig car because its a bigger pos then my truck
.. and the psd was also not getting plated as its slated to be scrapped from rot issues....so i let it go like that.
the stock injectors were still in the engine, as i was too lazy(frankly no time and back pain when i was not at work were the culprits there) to re-calibrate a set of the modified injectors that allow extended running on wmo so i let it go for the time being. eventually the stock injectors will plug off and the engine wont run. during this time the engine progressively smokes more and more.....it is running on used motor oil after all
the wife stepped on me to correct the issue as it was getting quite annoying. i knew it was getting close to being plugged off so i began the process.
some other issues developed that contributed to some other running oddities that needed troubleshooting. the injection pump, though new had the old outdated flex-ring dealio in it. the thick oil quickly wounded it....because the ip had barcode stickers on it i had assumed it was upgraded.
funny thing there, i had run into a retired military mechanic turned truck driver at the gas station who readily identified the engine(people are often curious about my truck for some reason) and warned me it likely had the shit drive ring in it, and from the beginning even with the pickup trucks they had the barcodes on them. and he sure as hell was correct all the way around.
i was surprised so i went to a gm board with a 6.2 section i belong to and inquired. there are many 6.2/6.5 ninjas there and its is extremely well moderated. after a short discussion things were inconclusive so i rolled the dice.
so i was trouble shooting the bad ip behaviors as it was not exhibiting the classic symptoms, this even longer story shortened i was in the process of swapping the injector pumps when i was called away to help another, when i was finally able to return to the project, it was looking like rain, so i fired the truck up....but did not make it ito the garage.....#8 cyl gobbled up the rag i left over the intake and after rectifying all of that mess a new noise was heard among-st the diesel clatter.
after a shit ton of trouble shooting, i had fragged the block by feeding the poor thing a shop rag
i am hoping to piece together something between the old 6.5 and this fresh 6.2 that will go down the road ..... just to get by for now
but installing head gaskets on the old powerstroke out there after i scrap the body and fitting it to the ranger is not out of the realm of possibility at thiis point.
ideally a mechanical duramax would be my top choice. i need to figure it out.
the 6.2 and 6.5 in mechanical form and stock are ridiculously reliable, and run on an amazing array of fuel stocks. but the problem comes where power is concerned...i would like 300 hp that can gobble alternative fuels with no fear of block failure....regular detroits like these wont do that. the prices have gone up steadily but the supply is still in a glut...dont make sense but it is what it is. if i can score a gep engine i will stay with this platform...but so far it looks like a duramax will be close to those costs....tough one.
so far the only problems i have had has been operator error. cranking up a 6.2 to 300 hp will be operator error as well. i want a 300-400k engine...not 40 k hand grenade.
what say you other diesel swappers??
on edit....its been almost 6 years exactly since i took my first test drive...
day umm.....hard to believe.
