- Oct 30, 2008
- 0
- churchton maryland
- ford
- Engine Size
- 2.3L
i have a rear end (minus the drums backing plates and shoes) from a 1990 ford ranger 4x4 that had a 2.9 i've confirmed its a 7.5 with 3.73's. my question is will the ring and pinion swap over to my 95 2.3l 5spd(has 3.45 in it) or should i not even use "used gears" in the first place seeing that i will completely lose the....uhh for lack of a better term "timing" that it was broken in at. and if this would work would i have to change anything other than the ring and pinion.? it only has RWabs so i think the gears would just switch over to the carrier no problem. i use this truck mostly for daily driving plus or minus the occaisional burnout or 2(depends on the mood my feet are in) and i've heard that the 4 banger runs more efficiently with 3.73's with the 5 speed.
and if none of this will work. anyone interested in a 7.5? complete with axles? 1 axle seal is bad and one of the axles may need to be repaired.. pinion seal may need replaced to.
any help would be appreciated
