7.5 help
tandksranger
troutman ,nc
I have a 89 extracab with 4.10s on 35 inch tires the front carrier is shot , found a new set of 4.10s on line . the question is are they the same ring and pinion front and rear , can you put a rear in to the front ( not the whole houseing )
small ranger
dirty south
171 c.i. of fury
No. The front has a dana 28 high pinion reverse cut R&P and the rear is a ford 7.5". Totally different.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The D28 is much too small of an axle for 35" tires (and so are 4.10s).
You should think about getting a D35 up under the front of that thing (along with a 8.8" rear too), and gear them to 5.13 if you have the 2.9L V6. This should improve both the driveability and durability of your truck immensely.
