8.8 street friendly locker
jovibuilt
9
Spruce Pine North Carolina
What is the most street friendly locker for a 8.8?I have a spartan for the front and would like to get a rear locker because I am getting ready to do 5.13's.Thanks
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Well, if you have the disc 8.8 31 explorer axle (assuming its the rig in your sig) then an Aussie's the ONLY way I'd ever go. I can't even tell its back there half the time other than going around a sharp turn taking off from a stop
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
The best locker would be an ARB.
Now if you don't want to spend $1000+ then i would go with an aussie. I had an aussie in my worthless Toyota and it was great compared to my Spartan lockers in my Ranger.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
To each their own, I suppose. Not considering price, I'd STILL choose the Aussie locker. They're stupid simple. They either work, or they don't.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I would go to a Detroit or Yukon Zip locker. The weak point of the 8.8 is the carrier, a full replacement locker solves that issue.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Yep.
I've had ARBs in two trucks over the last 16 years. I did grenade one about 10 years ago though it was an early design unit. Any of the ones built maybe within the last 12 years I don't think you can go wrong with.
FWIW, that one blown-up ARB I did replace with a Detroit Locker. It's been 100% trouble-free, however I'd try to stay away from it if you have a stickshift. The lash built into a Detroit makes it a little annoying with each shift (you have to feather the clutch a bit each time so it doesn't bang or lurch during engagement).
With an automatic this isn't so noticeable.
chrwilkins30
6
Mishawaka, Indiana
2.9
I just put a lockrite in last week and its not really noticeable like blinkers mentioned unless around tight corners.
Prob the most street friendly locker would be a ARB if you got the $$$.
jovibuilt
9
I should have gave a little more info last night.This is for a full width 8.8 out of a F150 thats going in my ranger.I think it 31 spline anyone know? I have a FW dana 44 to go in the front with 5.13's and a spartan locker.I dont have the money for a ARB or Detroit right now.I am just trying to get everything ready for my sas.The truck is a 89 with 4.0 5 speed.
4.0B2
151
Walls, MS
4.0 v6
I have aussie's front and rear on my b2 and you don't know they are there, till I'm in a parking lot. You get kinda used to not turning to full lock and then trying to accelerate.
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
I DD my lock rite and dont notice it anymore either. I did learn to coast my corners and accelerate when I am out of the turn. I learned not to hard launch unless you know both side gears are engaged as well.
-PlumCrazy
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
It depends if you hate open diffs on the street too. If it doesn't bother you, ARB for sure. I hate driving on the street and punching the throttle only to have 1 tire spin and go nowhere fast, so I like auto lockers. I really like the Aussie in my B2, but a Detroit or Zip is a stronger option.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I can attest to this.
Had a 31 spline explorer 8.8 in the 91 with 4.56's and a detroit...that truck was an auto....95% unnoticeable on the street.
Have that same rear end swapped under my 97 with the 5 speed and it's certainly clunky/bangy/popping a lot.
Hagan
11
Salem, OR
2.3
Thats exactly what my truck is. FW 8.8 in the back and FW Dana 44 in the front with 5.13's and spartans. The spartans were very cheap. I got mine from Rock auto for $500 for both lockers and it came the next day on a saturday!
The FW 8.8 is a 31 spline.
FritzTKatt
4
Ohio
My lock-rite is just about unnoticeable on the street, and does its job just as advertised on and off road.
Took more time to get the cross pin bolt (that little jesus/keeper bolt) out after the head broke off, than to install the thing. Stupid simple, works every time. Not hard at all to get used to, parking lots are a PITA sometimes, though.
