83 Ranger No fan speeds working.
flwsock
10
wisconsin
ford ranger
Hi all.
FINALLY got my ranger running well enough to make the trip from storage to my house to patch a shock tower. I noticed that none of the fan speeds work. Before I parked it, I believe one or two or the speeds didn't work. Back then I had replaced the blower motor itself. I looked at the resistor and had replaced it, but it made no difference so I put the stock one back in. But now since putting it in storage NONE of the speeds work. What should I check?
Thanks!
8,372
There should be a Fuse for the blower, 30amp, key on fuse
Heater fans get 12volts with key on, the speed control is the GROUND side, on HIGH its a direct ground from cab speed control
Lower speeds pass thru the resistor block
Which is why fan can work on high but not lower speeds(bad resistor block)
I would first check if fan has 12volts
You can use a sewing needle to pierce the Brown/orange stripe wire on the fan, then use volt meter or test light to see if there is power, Key ON
If there is then pull out the sewing needle and put it in the fans Ground wire, orange/black stripe
Turn speed to high, key off or on doesn't matter
And test that wire to battery positive, volt meter or test light should show 12volts, if so then fan motor is bad
If no Ground then you may need to pull the speed control panel and test its Cab Ground wire, Black wire
flwsock
10
wisconsin
ford ranger
Thanks, Ron! I'll give it a shot tomorrow and see what I come up with. I might've even overlooked a broke fuse. I think I checked it, but I'll double check just to be sure!
flwsock
10
wisconsin
ford ranger
Just checked it. We got no power at the orange wire, so we followed it under the fender cover. Turns out the connector to the fan fell off. I must've not of secured it well enough when I replaced it a few years ago (the plastic clips broke off). Picking up a new resistor now because the two lower speeds don't work. Thank god, finally an easy fix!
Thanks,
Karl G.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,708
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
How does the connector look? If it is all corroded like the one in '98 was, you might want to consider getting a replacement pig tail. Damn thing almost caught fire before the fan stopped working.
flwsock
10
wisconsin
ford ranger
Hey Sgt,
Pig tail could definitely use a clean up, but I don't have the time now to get another one. I'm back off to school today and just finishing some other last second things on the truck before heading back. All the speeds work now, though. So it must be decent enough. Maybe when I come back I'll try to clean up the prongs or get a replacement if I can.
