Fords4Us
- Dec 27, 2012
- 2
- Snohomish, WA
- Ford Ranger
- Engine Size
- 2.8L
I did the Duraspark conversion on my '83 Ranger last summer (with a lot of help from folks here; thanks again). It's been my daily driver since then, and until this past Friday it was running great. I was out running errands and all was well, when I pulled into a parking spot and turned off the ignition. The engine unexpectedly dieseled (continued to run for a few seconds before stopping). Hmmm. Went into the store, got my stuff, came out a few minutes later, and fired up the truck. Suddenly the ignition was sky-high, and I noticed a loss of power as soon as I engaged the clutch and tried to get going. Long story short, I had very high idle speed whenever I put in the clutch, but noticeable lack of power as I tried to move through the gears. The higher the gear, the more noticeable the lack of power.
We did some troubleshooting over the weekend and noticed that the distributor had drifted out of position (I had everything indexed from when I did the conversion). No problem - put the distributor back into position, fired it up one more time, idle speed had returned to normal. Turned everything off and called it good. Until today.
When I went to run errands again today, everything was where we'd left it over the weekend. Truck started right up, but as soon as I put it in gear and tried to pull forward, it died. I started to adjust the distributor again but at each possible adjustment, either my idle was too high or my power upon engine load was too low. I'm starting to suspect something else is involved. My first hunch is that a vacuum hose plug fell out somewhere, such that I no longer have the vacuum I should have throughout the system. I suppose I can categorically start searching for such a problem, but does anyone have any ideas for what else it might be? Full tank, no other performance issues prior to my sudden symptoms last week. Thanks all. You folks are the only reason that truck is still alive and kicking.
Kathryn
Kathryn
