84 Bronco II 2.8 to 302 swap...
fangotango306
8
sc michigan
None yet
fangotango306
8
sc michigan
None yet
and if you dont have an intake yet you can get a brand new edelbrock performer 289 from autozone for $100.....part number in their computer is 2121
PetesPonies
25
east coast
2.3l
I built this engine for fuel mileage :) I used a '68 block, new cast pistons, and a stock cam profile. I put on a set of E7 heads , slightly ported on the exhaust side but with 1.72 roller rockers. I used an '82 high rise 2V manifold and I built a 2100 carb. I used the stock log manifolds for fitment and of course all new bearings, lifters and accessories ( pumps ) etc. If I want maximum power in something, I won't be driving the BII so that wasn't the goal. I wanted as much low speed torque and efficiency as I can get from a small V8 with a carb. I have a Duraspark distributor that I am firing with a HEI module. I will probably end up changing the gears from the 3.45s to 2.73s or 3.08 etc. Not sure what I can get for the front Dana differential?? With the V8 torque, I don't need the lower gears to be able to accelerate well enough on the street. So there you have it. Now the original poster . . I'm guessing you aren't going to build an engine?? You want something that you can just drop in?? Or do you want to build one and just want a good starting place??
Dantebxvi
Bakersfield California
I'm in California and I'm thinking about doing a 302 swap in my 84 BII. Do any of y'all have any advice or if it will even be street legal in Cali? Thanks
Dantebxvi
302 swap in Cali
So I'm wanting to do a 302 swap in my 84 BII. I live in California and would like to know if any of y'all have any advice or if it's even legal in California. Thanks
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
i put a 5.0 HO in my ranger and it was farily simple. there were a few times i was standing there scratching my head but it all worked out. i went with HEI dist easiest way to go. motor mounts from 86 lincoln cont. 5.0 weiand intake holley carb and lots lots more goodies
What did your motor come out of.
And will 86 lincoln conti motor mounts work on my 01 Ranger edge.
Did you have to do any fabrication. Just curious what I can use other than explorer v8.
17,854
SW Iowa
I am curious too but he hasn't been online for over 7 years...
FWIW TTB trucks have a huge beefy crossmember that ties the frame rails and suspension together. Your truck is vastly different in the front.
IIRC Explorer mounts are a drop in fit for you, no idea how much they cost new though. I think my Mustang mounts were around $30 a side.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
Yeah, I knew it had been a while, just hoping somebody else had the info. V8 explorers are a hot item around here so if I can grab a different donor and Frankenstein the rest, I will.
17,854
SW Iowa
The mounting bosses in the block are all the same, you could put Explorer mounts on a '66 289 and bolt it in your truck.
The mounts should be available new, I would be tempted to use new ones no matter where the engine came from anyway.
