84 bronco II duraspark and carb conversion
mjr46
18
So I have put off my bronco 2 duraspark and carb conversion for the longest i can, 6 years ago i made a thread and have yet to convert it, the intake leaks oil bad, wire harness is deteriotatred bad, and carb is leaking.....i only use this to plow out community, it has gotten bad enough that i don't trust it to limp it through another winter..............I am having difficulty sourcing the parts, it appears i can get the cap, rotor, wires,cap adapter, coil and ignition box easy at the local parts store and rock auto has the non feedback carb for 240.00............however it doesn't appear anyone has the distributor available?? Does anyone know where i can get a decent priced carb and distributor asap to do this conversion.....i'd rather not have 500.00 in parts to do this, the truck isn't worth that.......any help is appreciated :)
mjr46
18
so rock auto had 1 302691 dizzy in stock...we'll see if it arrives as listed.........any ideas on a carb guys???
Junk Collector
Truck of Month
4,839
Rapid City SD
Any old Motorcraft or Autolite 2bbl from the late 70's or older will work... should be able to score one from a junkyard for a reasonable price and rebuild it. Carb kits are cheap. Just Google the number on the carb tag - there were a bunch of different venturi sizes throughout the years. $240 is way too much to spend on a carb, if you're gonna drop that kind of cash, a brand new Holley 2bbl would be the way to go although the factory 2bbls are fantastic, simple carbs.
I think that distributor you found will be fine, I sourced them from Mustang IIs back in the day but those are impossible to find now.
mjr46
18
most of the junkyards around here don't have old vehicles and i don't have time to hunt for them.........amazon sells new carbs for around 100 and the reviews are not bad......my question is would the larger venturi size be to much carb for the 2.8??
mjr46
18
since no one here has an answer to my specific questions......i'll reveal what i found....so the dizzy from rock auto came today and it is correct.....miracle!! now i ordered one of those 2150 carbs on ebay for 75 bucks, found a review where a guy used one for a bronco 2 duraspark/carb conversion and it actually worked well for the price so i took the leap of faith.....we'll see, i hope to start the conversion this weekend and finish it up thanksgiving day weekend, depending on how many snags i run into while doing it........update to come!!
17,915
SW Iowa
1.08 Venturi is what you want. The 1.21 is too much and throttle response will suffer.
mjr46
18
I didn't get the 1.21 venturi carb.......the ebay ones are 1.14........about the best you can do, finding a 1.08 is near impossible with the time frame i have to get this done.......1.14 won't kill throttle much, if it suffers i'll jet it back, but remember, this is a plow only truck and doesn't venture out of my community and 90 percent of the time it is in low range for plowing.....trust me, anything is better then what i have now, it has weak to sometimes no spark on bank 2 and fowls the plugs out on bank 2 and the carb leaks and ignition cuts out and thus making the truck backfire and blow 2 mufflers up so far.......so what i'm about to do will drastically improve how it runs.......i'll post up the results when it's done hopefully in about 2 weeks :)
17,915
SW Iowa
I tried the 1.21 and the rev hang was painful. It will be interesting to see how a 1.14 behaves.
mjr46
18
we'll see, how it goes.....i hope to start on it this weekend.......it's only used for plowing anyway :)
8,372
I think for reliability, the duraspark distributor with an HEI module is a better setup, and cheaper as far as the modules
Junk Collector
Truck of Month
4,839
Rapid City SD
Sorry I didn't respond, this new-ish forum software makes it a little harder to see which threads have new posts.
I second what '85 said, smaller venturis will be helpful... keeping in mind that they used those 2bbl carbs on a very wide variety of engines including the big Lincoln and Merc 429s, 400s, and others so they needed a lot more air and fuel moving through them.
I think the 2100/2150 were some of the best carbs ever made. A couple buddies of mine actually teamed up and built an adapter plate to run one on a Toyota 20r 4 cylinder with excellent results. They were very common on V8 Jeeps as well - AMC used a hodgepodge of everyone else's parts near the end of their demise/merge with Crapsler.
8thTon
--- Banned ---
806
Pennsylvania
Jeep used the 2150 on a 360, but those were the bigger venturiis.
mjr46
18
given the time frame i have to do this i got a 2100/2150 off ebay, new china made..lol with 1.14 venturis, tore eveything off yesterday and intake off to reseal.......waiting on gaskets now to arrive. so hopefully by next weekend i'll have it running if gaskets show up......amazing how no one stocks stuff like this anymore.
Everlearn
104
Louisville KY
Ford Ranger 4x4
Folks I just happen to have a Motorcraft 2150. It’s a 1977 carburetor with 1.08 venturis. It appears to be in very good shape. I also have a new rebuild kit I ordered for it. I’m down the Offy 4bbl rabbit hole, so I won’t need it. Make a reasonable offer and it can be yours!!
mjr46
18
nice....we'll see how my ebay china deal works......hopefully well or i may be in the market in a week or so...lol stay tuned :)
