84 ranger headlight issue
chayse brooks
I have a 1984 ranger when I turn the lights on I have to use my high beams or the lights will not work. After a while of the lights being on the lo beams can work to but they only turn on about 15 minutes after the headlights are turned on. I thought it was the hi lo beam switch causing this but I'm not to sure anyone else having this issue
3,614
Have you tried replacing the bulbs?
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
there is a circuit breaker built into the main headlamp switch which gets twitchy with age,
ant particularly if the hi/lo contacts inside the multifunction (dimmer) switch have become worn.
I recommend replacing BOTH switches
I've personally repaired dash wiring damaged wiring (and near fires) caused by both switches
AD
