85 Bronco II lift qustions
hende
Oregon
FORD
2.8
Thinking of adding a lift to my b2 but cant figure out what I want.
2 or 3 inch?
body or chassie
if i do a 2 or 3 chassie do i need to do anything to the steering?
if I do a body lift I dont seam to be able to find bumper brackets to lift my bumpers up to match do they make them?
tires a 30/10.50 will they look to small with a 3 inch lift?
Thanks hende
stegomon
20
auburn/minot maine
fords and only
i have a james duff 3 inch lift in mine. got it along time ago. the lift has been in 2 other ranger. but i always like suspension lifts better than body lifts. it gets your oil pans and gas tank further off the ground. i could fit 32s with my lift. but i am rockin 31s for now. oh and i cant find a bumper bracket for the gen ones as well.....i have seam some people cut the front of the frame horn off and and relocate it.
ClaytonBigsby
PNW
Turd.8
I did a 3" body lift on mine and had NO probs. The kit came with a steering attachment, but I didn't even have to use it. It's been almost 20 yrs, but I think I just unscrewed the black plastic shield between the body and bumper and let it sit at an angle. It looks totally normal. I also put in 30's and have no probs with any clearance. Spent about $115. If you just want to get taller for bigger tires, it's the way to go. If you want to get off road, suspension.
4.0B2
151
Walls, MS
4.0 v6
I wouldn't say it looks "totally normal".. the gaps are large... and the space between the body and frame in the rear fender area is noticeable to.
my problem w/ the body lift was the motor was low down in the hood, making it a pain to work on. you don't think about that till you have to do it... I'm already short, then raise the truck around the motor, but the motor still sitting down at the original spot; made it hard for me to reach stuff.
On some Bodylifts (different for each vehicle) you'll need to extend your gas tank filler neck, mine pulled off when I lifted the body. the shifters might need extended. the steering (unbolt it from the firewall when lifting) might need played with. the bumpers hang to low, but if you raise them, you'll have to raise your hitch and exhaust tips (if you have them)... so on, so forth... to make it look right, its a good bit of work.
personally I'd piece together a suspension lift w/ good brackets, custom extended radius arms, explorer axles, jeep XJ coils, and homemade sway bar disconnects for the front and belltech shackles and an add a leaf (if needed) for the rear. Of course you'll need longer shocks and probably brake lines. Plus I might be missing a few things...But if you search and find used parts you can do all this cheaper than the GOOD suspension lift kits and have a better setup.
hende
Oregon
FORD
2.8
how about the gas filler neck?
ClaytonBigsby
PNW
Turd.8
The gas filler neck?!?!?!? That may explain my poor gas mileage. Kidding, the only thing I noticed was the shifter (TK5) dropping two inches but that worked great for me. I didn't like it at the original height. I'm in "The Couve" if you want to take a closer look to make up your mind.
To 4.0B2, Either way it sounds like you're standing on a ladder ;) Jealous of the 4.0!!
Also, I like the bumpers where they are. Any taller and a car might slide under the rear and blow me up. The front is good for pushing another car without smashing its tailights. My $.2
