85 ranger 2.8L a/c delete
85rangerdanger
Elizabeth City, NC
I took the compressor off since it doesn't work but don't know what to do about the two hoses connecting to it can I just take them off?
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
If you're not going to be using the a/c just take everything out. It's just in the way.
85rangerdanger
Elizabeth City, NC
What parts
Would I still have heat ig I just took those two hoses that connect to it and just cut them off ?
85rangerdanger
Elizabeth City, NC
Also what about the smog pump I took the rubber hoses off and don't know how to go about plugging the metal line by the back of the valve cover
ericbphoto
Overlander in development
16,627
Wellford, SC
3.0L
6"
The heat is separate. There are 2 heat exchangers in the ductwork in your can. One is the A/C evaporator coil and the other is the heater core. If all you do is remove A/C stuff. That will have no affect on the heat.
This message composed solely of recycled electrons. Go green!
How am I supposed to know if I'm asking it
I am trying to encourage critical thinking. All cars have heat. Not all cars have air conditioning. So by that logic if you remove the air conditioning parts the heat should still work.
ericbphoto
16,627
Wellford, SC
3.0L
6"
Also, if the air conditioning is already non-functional but the heat still works, then it can be concluded that removing the air conditioning components should be ok.
Right.
85rangerdanger
Elizabeth City, NC
I'm new
I'm new to this forum and to even having a carbed engine and I've never taken a/c put before thank you for your help
85rangerdanger
Elizabeth City, NC
I'm new to all of this I've never taken a smog pump off or deleted the A/c I bought this truck as a project and haven't evits gave it it's first test drive I got it running but the brake pedal is really hard and I have to press hard for it to stop in gear just in the drive way I'd really appreciate all the info and help I could get on all the upcoming work thank you in advance
85_Ranger4x4
17,907
SW Iowa
Go whole hog and wipe out as much of it as you can. Remove the plastic housing the blower motor mounts two, take off the access panel and pull the evaporator too and reinstall it. It will move a lot of air (especially if yours was like mine and plugged up with dirt/debris) OR get a airbox from a non-a/c truck. It will take up much less space in the engine bay (aka easier access to #3 spark plug) and look nicer.
The pipe was plugged on mine before I got it, IIRC the PO used a large bolt in a hose. Come up with something cleaner. I remember I used a non A/C PS belt for the alternator side (so both belts were the same) and it fit perfectly.
Check your vacuum, you may have a leak that is messing with the vacuum booster. Or you may need a booster. Troubleshoot everything, don't just throw parts at it.
85rangerdanger
Elizabeth City, NC
I bought it for $400 guy I bought it from jipped me carb had caught fire and found out some vaccum lines were charred so I havent fixed them the hose running from the booster sis still good and is hooked up but the vaccum lines are plugged how would I go about fixing this
fastpakr
2,837
Roanoke, VA
Look at the lines one at a time and figure out where they go. An '85 2.8 will have a ton of them if it's still running the stock feedback setup. You may want to hop on eBay and buy an '85 EVTM guide.
