85 Ranger 4x4 build project
StephenF
35
East TN
Ford Ranger XLT
2.8 V6
I have the 85 4x4 from my welcome post and a 84 RWD that have had parts switched around. To start the project off I picked up a 83 300 from a 2WD F-100. Got the non-plastic radiator with it and checking on a T-18/19 transmission for it as well. Have to work on a 15 Tahoe before I get to tackle this project. I want to start by dropping the tank and seeing what I need to do to fix the level sensor. Then I will start fitting the 300 in place. Expecting to have to shift the cab back for everything to fit. After that I have to figure out axles. I am leaning toward Dana 60's, but set on nothing yet. I wanted to just use a Dana 35 TTB, but too limited availability on gear ratios for it.
8,370
Not sure I6(300) will fit Ranger engine bay as is, length is 30-33"
The 302/5.0l V8 short nose is 27.5" and it barely fits
302 is 21" high, I6 28" high
So shift cab back and UP as well
StephenF
35
East TN
Ford Ranger XLT
2.8 V6
Already has 4 inch body lift. Also looking at electric fan mounting options for a little added space up front. Of course, until I start putting it in place and actually seeing what is happening I have no clue exactly what is going to be needed. Not opposed to a little cab fabrication also if it doesn't interfere with anything .
alwaysFlOoReD
5,096
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
There is at least one 300 in a ranger I've seen in this forum. There wasn't a lot of detail on how he shoehorned it in.
StephenF
35
East TN
Ford Ranger XLT
2.8 V6
Yeah, did a lot of research about it when I first got the truck. Find a few threads here and there, but no real info or photos.
No members online now.
