86 2.3l turbo in 95 obd2 ranger
95ranger2.3
frazeysburg OH
2.3 turbo efi
i have swapped an 86 2.3l turbo from a thunderbird turbocoupe into my 95 ranger which is obd2. i seem to have everything working besides my no spark issue. i have one spark when i first start cranking and no spark while cranking. the engine has new pick up coil, new rotor button and distrubuter cap, new ignition coil and ignition module. any ideas?
poberly
2.2 diesel
You might have been given a bad coil. I had a truck that wouldn't run and it turned out that my coil would give me two strong sparks and then that was it. Hope it helps
70roadrunner
8
sedro-woolley, Wa
1970
194
plymouth
2.8
ddid you install a condensor? is it bad? i did an electronic ignition conversion once on a 60's musclecar and didnt install a condensor. had the same symptoms
