You are changing from a 1G alternator to a 3G alternator
So you are going to remove the External Voltage regulator.
You need the 3 wire connector for the new alternator, it will have:
Yellow wire
Light Green wire
White Jumper wire
There should be a Larger wire that was connected to a Stud terminal on the original alternator, that will be connected to the Stud terminal on the new alternator, its called the B+ terminal, this is connected to the Battery Positive all the time, the main Charging wire, high AMPs
External voltage regulator will have a Yellow/white stripe wire from truck harness, that needs to be spliced to the Yellow wire on the new 3 wire connector.
This is the Monitor wire, it tells the internal voltage regulator the current system wide voltage, i.e. when you turn on the head lights, power demand goes up so voltage regulator increases AMP output of alternator.
There will be a Light Green/red stripe wire on the external regulator, that needs to be spliced to the light green wire on the new 3 wire connector, this is the ON/OFF switch for alternator, it only has 12v with Key ON
White jumper wire plugs into alternator's Field, it is a spade terminal next to the 3 wire connector, this monitors voltage output
Remove external Voltage Regulator and its other wiring
If you have a Carburetor and electric choke you will need to add a relay to active it with key on power, if Fuel injected then no electric choke
If you have an AMP meter instead of a Voltage Gauge in the dash it should still work
Any alternator's AMP output changes with engine RPMs, the Point of a voltage regulator is to maintain 13.6volts with engine running, 13.5-13.9v won't "cook" a battery, but it will keep it charged.
Right after startup you should see 14.5volts or higher, but under 15volts, this is the "fast recharge" since battery was just drained by starter motor.
Voltage should drop within a few minutes to under 14volts and remain there until engine is restarted
After voltage has dropped to 13.6v or so, turn on all the electrics in the vehicle, headlights, fan blower to high, dome light, ect.....
Voltage should drop for a second then voltage regulator should respond and voltage should return to 13.6v if that is what it was.
Raise RPMs, voltage should go up for a second but then come back to 13.6v.
These are tests that the voltage regulator is working, and all 3 Fields in the alternator are working
