green'87-4x4
- May 3, 2024
- 0
- Santa cruz
- Ford Ranger xlt
Hello all, new to TRS. I bought a project 87 with the 2.9l engine. The previous owner threw lots of money and parts and couldn't get it to run. Even rebuilt the engine. I've discovered through a vin search that it was originally an automatic. Odometer indicates it hasn't driven in almost 10 years. And there's been multiple owners who have swapped trans, built brush guard, rebuilt and swapped engines etc.
So I bought I bit of a mess but I'm hoping I have more patience than the others and can figure this out, get it running and use it as a farm truck in California.
The PCM has a sticker on it that says for Taurus and Sable 3.0 only.
Can I trust this? And assume I need to buy a manual trans pcm for 2.9? I've never seen another PCM to compare to.
Any other wiring details that may be missing I'd love to hear about it.
New from previous owner:
iac valve
Air temp sensor
Aftermarket Coil
Distributor
Aftermarket Injectors
Work done by previous owner:
Two new catalytic converters
Rebuilt engine honed cylinders
Resurfaced heads
Pulled hair out (assuming)
Spent $3000 in parts and machining
Since I've had it:
I bypassed a melted connection to inertia switch.
Checked Fuel is coming to rail
Has spark
Corrected 180 out distributor timing
Cleaned out throttle body
Going to replace TFI mod today
I'm aware that cam timing might be 180 out. Good thing it's non interference.
Any tips and things to double check would be greatly appreciated. I have read lots of threads but figured I'd start one anyway.
Thanks for reading
iac valve
Air temp sensor
Aftermarket Coil
Distributor
Resurfaced heads
Since I've had it:
Has spark
Thanks for reading
