- Sep 21, 2007
- 671
- Wa, Bremerton 98310
- Ford
- Engine Size
- 87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
- 2WD / 4WD
- 4WD
- Total Lift
- Ranger 5" (1½" suspension), BII 4" suspension
- Total Drop
- Ranger 5sp, BII A4LD
- Tire Size
- Ranger 33"/4:10LS, BII 33"/3:73LS
- My credo
- Deengineer until it is how Blue Oval should have sold it!!
Hello,
PREFACE
**this 1987 BII has a complete 1994 Explorer EGR 4.0L/dash/cab and engine bay wire harness/ecm swap**
I finally have a replacement column for my 87 BII which came stock with a floor shifted A4LD and manual transfer case. My replacement column is from a 94 column shifting unit.
I have never wanted a column shifter and with the manual Transmission and transfer case shifters on the floor, I REALLY do not want the column shifter to be used.
What I need to know:
A) can I use my 87 A4LD with floor shifter with this 94, 4.0L/ecm setup without shift point or overdrive issues?
B) should I use the column shifted A4LD instead and why?
PREFACE
