'87 Bii 4x4 w/ power steering. Looking for a good 2" inch lift, preferably keeping the TTB front suspension.
Ottieotter
California
Ford Bronco II
Explained in title
franklin2
1,777
Virginia
Bronco II
Ottieotter
California
Ford Bronco II
This says it's for the full size Bronco/F-150, would I have to do any modification to get it to fit the Bii or does it just bolt right up?
alwaysFlOoReD
5,163
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
That is the incorrect lift kit. Input your truck specs and the correct kit should show up.
franklin2
1,777
Virginia
Bronco II
Sorry. Wrong link.
Here's a cheaper kit. It's just the springs with no brackets, but it only goes to the max for this type of lift, 1.5 inches. Even then your alignment guy will have to spin around and click his heels 3 times to get it aligned.
All this company offers after that is a 4 inch kit that has all the brackets and stuff to properly lift the ttb.
Ottieotter
California
Ford Bronco II
Sorry. Wrong link.
I saw the 4-inch lift, not looking to go that big. This truck is my daily, and I have no use for that big of a lift.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,608
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Check out James Duff lifts...
You can always add a body lift instead.
With lift kits... buy once... cry once.
Junk Collector
Truck of Month
4,869
Rapid City SD
That's what I would suggest. They basically copied the Ford STX High Rider lift brackets and added their own springs/shocks/etc. A drop pitman arm might be needed as well, for some reason those aren't included with that kit.
If you want to be really cheap about it though, you can get coil spacers for the front and taller blocks for the rear.
