87 Heater Core Replacement?
LD57
39
San Antonio
Howdy. I searched a bit but don't see anything on replacing a core. I *suspect* mine might be weeping a bit, not confirmed, but it looks at a glance like it'll take a sawzall to get in there, lol. Anyone? My other ride is an E30 beemer, and after reading horror stories, got in there and did it in under an hour. Hoping this is the same?
rusty ol ranger
2.9 Mafia-Don
7,626
Michigan
177 CID
Its stupid easy to replace the core on a 1st gen...i think it takes me about 30 min lol
Jazzer
457
Indianapolis
^Can confirm- use new foam where the tubes go through the firewall and you’re golden.
-Jazzer
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,739
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Lucky! Most vehicles, you have to remove the entire dash to change the heater core.
LD57
39
San Antonio
OK, so the 3 screws out is easy, but that bottom right piece of the cover that goes into the firewall..... is it screwed in on the other side? It sure don't wanna come out of it's hole! I can't see didly under the cabin blower without pulling the air box.
LD57
39
San Antonio
-Jazzer
I got "dumb dumb" tape apparently.
LD57
39
San Antonio
AHA!! Hidden screw inside the cab I missed!
Jazzer
457
Indianapolis
You’re about done!
If you have a flexible funnel you can mostly prefill the core before putting the hoses back on, it helps with getting the air out.
LD57
39
San Antonio
It was getting dark and I had to bail on the project. It'll get done over the weekend, and good idea about the pre-fill!
I have flush t's in the heater core lines for quick bypassing, as the blend door doesn't block it for beans, It's bypassed most of time since it's always hot here!
LD57
39
San Antonio
Yep, it was easy once I got to it! And just in time for a big cold front! :bye:
