88 Bronco II A/C
ronclark
25
Woodland, WA
95 4.0 with 93 ECU
I am working on my mom's Bronco II, I searched and I can't seem to find a solution for my problem. I think it might be the ECU.
I can't seem to get power to the AC compresser clutch. I check the pressure switch it's closed, I have refrigerant. Fuse is good.
When i push the AC button all I get is short clicks out of the WOT relay, I tried a new relay same thing.
I have a EVTM for a 87, I cant Imagen there much difference from 87 to 88 and it looks like the wiring is really simple.
Switch>relay>pressure switch>clutch.
Would there be any reason for the ECU to keep the ac off at idle?
Last fall I cleaned the throttle body and reset the TPS according to the manual.
any ideas before I rip the AC wiring harness out and check it for problems? :icon_confused:
jeremysdad
ASE Certified Tech
Are you using a meter to test, or just basing on operation (or lack of)?
I would jumper it with a hot from batt to verify that the clutch works before digging too deep.
If that doesn't work, it sounds like a wiring/connection issue.
Let us know!
ronclark
25
Woodland, WA
95 4.0 with 93 ECU
Let us know!
Well even though the pressure switch had continuity with the OHM meter it was bad. I replaced it and all is well again. [emoji1]
Sent from my SM-N920T using Tapatalk
jeremysdad
ASE Certified Tech
Sweet deal. Glad you got it going. :)
