- Aug 23, 2015
- 87
- Virginia
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 2.9
- 2WD / 4WD
- 4WD
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 235/75/15
I’ve got spark so figured I start a new thread. I replaced the coil and I’m getting much stronger spark now. I can get a very small hope that it will start then never commits. I can’t find a compression tester with a small enough hose clamp that will slide through the block to meet the plug threads. Still have good fuel pressure (36 psi) and it won’t start with starting fluid. I’ve pulled ECM and it looks mint inside. Anyone see any issues in the pic? I’m going to flip the rotor 180 degrees one more time for giggles. If that doesn’t work I’m not sure where else to look.
