- Jun 2, 2012
- 8,373
- canada
- Ford
1988 didn't have "Flash to pass"?
Thought it did
When you pull turn signal stalk(multi-function switch) toward you it will flash the High Beams whether main light switch is on or off
That's "flash to pass", it has 12volts all the time
If you push the stalk in/away from you that's high beams and its powered from main light switch like the low beams, so only has 12v when Main switch is on
There is just 1 wire out of multi-function switch for Flash to pass and High beams both, so if nether is working then could be the wire
If one works but not the other then wire is OK
There is a separate wire out for Low beams but they share the same 12v from main light switch as high beams, but not "flash to pass"
Thought it did
