9" Swap
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Ahhh....forgot about that writeup.
So you are going full knuckle.
Not all of the 35 beams have the deep overlap like those ones. But that is ideal.
I also think he overdrove and offset the knuckle too deep like I did the first couple times we tried it in the 90s....which moves the axle centerline from optimum. I seen that truck at an off-road park in mich and that is what I suspected....but he had reported no notable issues.
Definitely worth doing if running 35 inch or larger tires
chazzone
9
Camby, IN
So...how do I make sure I don't offset the knuckle too deep?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Slow. With a fresh setup measure the shaft height and make a jig block that sits in the beam.
Then use that as a guide
