- Feb 25, 2010
- Reaction score
- 5
- Location
- GA via NC Mtns.
- Make / Model
- ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 4"
- Tire Size
- 31X10.50
I have a 90 B2 5spd, new fuel pump, new fuel pressure regulator, and get spark with correct timing but it will not fire up when turned over. But I can get it to run when I spray ether into the TB and it runs quite fine. One thing I noticed is when I pull the return line off the fpr and turn the engine over gas comes out somewhere on the intake, but it does not when the line is hooked back up. Could the computer cause just the fuel injectors not to cycle? Would a computer from an auto 89 work? The engine doesn't even backfire when just using gas-nothing. Any ideas? Thanks.
