90 ford ranger tranny fluid
zxd5298
Hello everybody i just put a new clutch in 1990 ford ranger it has the 2.9 v6 5 speed manual 4wd, i was wondering what kind of fluid i should use and how much for the tranny and transfer case
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
The transfer case is easy... ALL transfer cases in Ford Rangers use Automatic Transmission fluid...
The transmission is a bit harder to pin down because it depends entirely on which transmission your truck is equipped with
The Mazda built transmission (M5OD-R1) uses ATF, this transmission has an integral bell-housing
The Mitsubishi trans (FM146) has a removeable bellhousing and a sheet-steel bottom cover, this transmission uses 80w Gear oil.
AD
AllanD
TRS Technical Staff
135
1987... sorta
'93 4.0
+1 ^^^
1988 to 1992 Ranger with 2.9l and 4x4 had the Mitsubishi FM146
2WD 2.9l had the M5OD-R1 during those years
You can look at the visual differences here: http://www.therangerstation.com/tech_library/ManualTransmission.shtml
Not True! the Mazda M5OD-R1 trans was available from 1988-on
The Mitsubishi transmissions are "more common" behind the 2.9 engine, but remember the Mitsubishi FM146/FM132 was NEVER Made for the 4cyl engine (or for that matter for any engine other than the 2.9), so the Mazdas were out there but Mazda was still ramping up production of this "new" transmission...
I've seen (and pulled) a number of "M" code transmissions in 1988 and 1989 model year vehicles, so don't repeat the false myth that they don't exist...
I actually owned an '88 Bronco2 with a factory installed Mazda transmission.
8,374
Not false just not common which is why I included the visual reference link.
Sometimes you find a unicorn, but most of the time it is just a horse
zxd5298
Ok so i do have the Mazda m50d-r1 iv heard of people using redline mtl in replace of the atf is that possible and if so is it worth the $$
