92 Explorer 4.0 issues
Roseburg. Oregon
2.3
So, now that I have had things up and running. Been trying to track down this miss I have. I have limited time to work on it which makes it frustrating. Seems really doggy, poor fuel milage (11 mpg on two tank refills) sporadic backfire when idling at a light. Occasionally after running around town a bit, when I shut it off and go to refire it will idle sporadically (800-1300 bounce) and clear up in within 10-20 seconds. I had one place try and use their scanner on it, they said their scanner would not maintain connection. I do not have a CEL on the dash (it does work)
Here are things ive done
New Motorcraft copper plugs gapped .054
New Wires
New Air Filter
Cleaned MAF
Bottle of Technron thru the tank
Tested resistance on the coil. Primaries all were .8 ohms on 200 ohm test. Secondaries were all 12.8-12.89k on 20k ohm test.
I am not 100% sure how to test the switching signal on the coil.
I am a bit boggled as other things I could check. I am getting ready to pull the plugs again to see if it will give me clues to a particular cylinder or cylinder set. Need to replace fuel filter as well.
Could use help and input, 11mpg sucks, just not as bad as sluggo performance
tcbaklash
Central WA
Bad O2 sensors can ruin your fuel economy. That might be something to consider.
Roseburg. Oregon
2.3
I agree, I went to town to try and have codes ran again... both times they cannot get the code reader to connect......... I figure I will have to try and manually pull codes this weekend if I have time. this 60 hour work week sucks. tryin to make me work saturday on top of it.
Just a little update is the MAF cleaning seemed to help a little bit. still going to do what I can during the week
