broncobuckinaround
- Sep 24, 2012
- 1
- ford
- Engine Size
- 4.0
everytime i go on a long drive after shutting the car off on turning it back on after 30 mins more or less. it will shake like hell and sputter when i put in drive, sometimes will die. but always will restart with the same symptoms. they will eventually go away. and the car will smooth out.
i have done the intake gaskets. only because i read a forum that said they werent torqued correctly from the factory. it was true for this one. all of the lower intake bolts were finger tight. no wrechs needed. while i was in it i cleaned all the fuel injectors by running b12 cemtool through them.
i replaced the fuel pump, fpr, haven't done the filter yet cause its not that old. the guy before just did it. so its only got a few years on it.
basic tune up, plugs and wires. i did the tps for shits and giggles. air filter. o2 sensor. gutted the cats cuz theres no emission where i live and im sure they were getting clogged up.
so im not sure where this problem is coming from. fuel pressure is right where it needs to be running and not running.
need some extra help on this one
