92 ford.ranger 2.3L
William r
Lynnwood wa.
Injust replaced water pump. Ran truck a few locks to a store. Then idle started. To act up. Then trump k died. Won't start. Got.spark got gas fow. Could I have broke the timing senser when I was installing the water pump. It was dark and working g on truck in a snow storm. Could I have hit.somethi ng ?
8,372
Welcome to TRS :)
Do 50/50 test
Spray gasoline or Ether(quick start) into the intake and then try to start engine
If it starts and dies then you have a fuel flow issue
If it doesn't start then you have a Spark or Compression issue
50/50
Crank sensor is behind the timing belt cover in a 1992 2.3l Lima engine so unlikely you disturbed it
But its wires run out from behind the back cover and connect to the ICM(spark module) that is located on the front of the lower intake, near where you were working
Timing belts on these engines can break, it doesn't hurt the engine but it, of course, would not start up after that.
You can usually see the cam gear behind the cover at the top of engine, make sure it is turning when engine is cranking over, if not............broken timing belt
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,798
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Welcome aboard!
