'92 Ranger 3.0 2wd Hub Nut Torque
susieranger
'92
Anyone know how tight I should torque the front hub nut on my Ranger after packing the wheel bearings. Thanks very much.
Earl43P
38
Farmington, Pa
Ford F250 4WD
Run it on fairly tight, but not gorilla-torque, while you spin the wheel.
Back it off so the cotter pin hole lines up. Done.
TireIron
Methuen, MA
no, its a 3 stage torqueing process, you torque it to 25ft-lbs while spinning the rotor to seat the bearings, then back it off 1/4 to 1/2 a turn, then torque it to 16-18 INCH-lbs, which is about finger tight.
