black_demon69
- Jun 30, 2013
- 142
- AZ
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0l
- 2WD / 4WD
- 4WD
OK misses @ idle
I have replaced all 8 plugs (had 4 different kinds of plugs in it)
Replaced wires (all miss matched)
Replaced coil pack for intake side plugs
Compression is @ about 70psi dry 95psi wet on all 4 cylinders
Fuel pressure is @ 35psi and 40psi with fpr disconnected (fuel pressure drops like a rock when key is off) (I will be replacing pump soon)
Timing marks line up
A couple of notes
Spark plugs have a nice brown coloring
And it does pop through exhaust
CEL is off a d no codes
Thoughts suggestions? Where to proceed from here?
A couple of notes
