surratt
- Mar 28, 2010
- 1
yeah so i swapped in a 93 5.0 in my 87 bronco 2. Has a c4 transmission. HAvent really dud deep trying to fix it yet but basically I start it up and it idles ok for a little but after a minute of driving or two it will stall at idle or deceleration at times. I can drive it but i have to powerbrake and give it gas. Engine is low mileage and plugs are new.
Pre obd2 stuff is harder for me to diag. Im going to start by smoking it for vacuum leaks. I set the distributer to where i had it before but i dont have a pointer for the crank installed. Need to get that set up and double check the ignition timing. Im using a throttle body/intake off a later year 1998 explorer I believe.
what are some common areas to look at for this idle issue?
