94 3.0 to 4.0 Conversion
gungfudan
19
Mississippi
Mazda
N/A
N/A
I have some questions on the difficulty of swapping from a 94 3.0 to a 4.0 similar year OHV or earlier?
Will the Transmission swap from the 3.0 to the 4.0?
Can I use any of the wiring harness from the 3.0 to the 4.0?
Do I basically have to change everything?
JOLENE_THE_RANGER
204
long beach, ca
short answers
no
its possible but way harder than finding a 4.0 harness.
yes
Transmission is a no go. The bell patterns between the two are not even close. The starter is in roughly the same spot, that's as good as it gets there.
Harness, can be done, but as said it is quite a bit harder than finding a 4.0 harness. One person here, who's user name escapes me at the moment, is running a 4.0 in is 98 with a 3.0 harness. OBDII is far pickier than EEC-IV. The big issue you will run up against is that the 4.0 was always EDIS, and the 3.0 had a distributor up until 95.
So yeah, best to just change everything.
8,372
IMO, not a good swap just because you can got out and buy a factory 4.0l Ranger
Anytime you swap to a different displacement, you need the engine/trans, computer and wiring harness for that engine and computer
So 3.0l to 4.0l is the same as 3.0l to 5.0l(V8) swap, but with a V8 you have something the factory never made, well to sell publicly, lol
Well one exception, 2.9l to 4.0l swap was not as complicated a displacement change
