MA Ranger
- May 19, 2009
- 0
- Ford
My '94 XLT (3.0, 2WD, automatic) has suddenly developed a severe shudder/vibration that appears to be coming from the engine (it varies with pressure applied to the gas pedal and is the same with the transmission in drive, park or reverse so I don't think it's in the drive train or transmission. U-joints were all replaced about two years ago.). Other symptoms: exhaust louder than normal, decrease in gas mileage and less power. It was running normal a few days ago. I parked it for about 10 minutes after driving at highway speeds for about 100 miles. When I started it up and backed out of the parking spot, the engine was shuddering and vibrating when I stepped on the gas and the exhaust was noticeably louder. At lower speeds and when the engine is under a load (accelerating from a standing stop or going up a hill), it almost sounds like a motorcycle. The vibration smoothes out a little bit at driving speeds around town (40 - 45 mph) but it's definitely still there.
What I've done so far:
Put a bottle of Gumout Regain fuel system cleaner in the gas tank (I normally put fuel injector or system cleaner in it about twice a month and I cleaned both the lower and upper intakes when I took them off the engine about six months ago)
Scanned the engine - Key on Engine off (KOEO) test. Both hard and continuous codes showed "111" system pass (the "check engine light" isn't on)
Did a simple check on the EGR valve - temporarily blocked the port to the upper intake with sheet metal - no change in any of the symptoms (I did this to check if the EGR valve was stuck in the open position).
Is it possible for the Powertrain Control Module to be bad, but still be able to pass a KOEO test?
Any help would be appreciated. Thank you
