94 4.0 dies with any amount of throttle
stsalvage
20
moreno Valley
i have 2 ranger
Ranger XLT exte
4.0 & 2.3
stsalvage
20
moreno Valley
i have 2 ranger
Ranger XLT exte
4.0 & 2.3
2.9 and the 3.0 and the 4.0 use the same Cat
cougar190
Stamping Ground, Ky
1 1990,2 1994's
2.9 and 4.0
Look at the tube that goes from your air filter box to your the plenum. I had a 92 Ranger that would start and run idle as a top but if you got off idle it would dye. If you slammed the throttle from idle it would jump and run until it got close to max RPM then start lurching/stalling. Like a huge vacuum leak, turns out the tube was cracked in the areas where it has the flexible joints. Hope this helps! ...cougar...
