94 ford ranger zerk fittings
edwardhawkins37
Canton, GA
Ford Ranger XLT
Hi! Does anyone happen to have a diagram should all the grease zerk fitting locations on a 1994 Ford Ranger?
Thank you.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,580
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Take a look in the Tech Library... there are owners manuals there that will probably have that info.
ericbphoto
Overlander in development
16,743
Wellford, SC
6"
OEM, there aren't any.
By 94 (and earlier) they were building vehicles with prelubed, nonservicable parts. Best thing is to get under there and look to see if a previous owner replaced things parts. Look at u-joints and steering/suspension bushings.
Uncle Gump
Token Old Guy
13,580
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I just thought of that too... the entire lubed for life thing...
But as stated... a lot of replacement parts have grease fittings. Just dive right in.
sgtsandman
Aircraft Fuel Tank Diver
12,793
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
IF there are any zirc fittings, look at the outer tie rod ends, upper ball joints, lower ball joints, and drive shaft u-joints. If the parts are factory original, the chances are next to zero that they had any.
