94 Ranger push button 4wd not working
sd359
Law Enforcement
6
Rocky Mount, Va
Went out today and hooked up to my boat pushed the 4wd button and nothing. I checked the fuse in the power distribution box it was good. Could use some help in finding the problem. Don't know if it matters but I moved the bed back and replaced the gas filler tube the other day but have done it before with now problems. Any help would be appreciated. 94 Ranger 4.0 5speed extended cab XLT. Thanks for any help.
ericbphoto
Overlander in development
16,734
Wellford, SC
3.0L
6"
Clutch in or neutral, if automatic?
Foot on the brake?
0 speed?
Held the button for a few seconds?
sd359
Law Enforcement
6
Rocky Mount, Va
Foot on the brake?
0 speed?
Sitting still, foot on the brake, in neutral and clutch pedal on the floor, held for a few seconds tried this numerous times, tried it with motor running and motor off nothing.
Josh B
1,988
Oklahoma
Your next step may be taking it apart and checking for any corroded connectors. If you have a meter you might check currents getting through it
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,558
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
There are several diagnostic procedures in the tech library...
sd359
Law Enforcement
6
Rocky Mount, Va
Thanks for the help. Unhooked and tested the 4wd module behind drivers seat, it was fine, plugged the harnesses back in and it works. Must have been a bad connection to the module. Again thanks for the help.
00t444e
217
Southern OH
Ranger ext cab
That's something you have to deal with on those junk electric shift systems. It's best to swap to a manual shift transfer case.
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
Oh come on I don't think they are junk. Given that manual xfr control has less points for failure, but is it worth the trouble to change, I dunno.
I don't have push button it's a switch, but that's basically the same I guess. I always say 90% or more of electrical problems are bad connections, that's my experience true or not, so that's the first thing to check before jumping to omg it's a huge problem.
Might be a good idea, if you don't use 4x4 much, to periodically find a dirt/gravel lot and "exercise" it so when you do really want it chances are better you don't run into an issue.
When you start up the 4x4 hi/lo lights should flash on/off not sure what that tells you but if they don't that would indicate to me something ain't right. I would imagine it's checking to see if there's continuity to the xfr motor but others would know more than me.
ericbphoto
16,734
Wellford, SC
3.0L
6"
My electric shift t-case is still original.and works great. Just make sure you cycle it periodically.
