96 ext cab load limits and upgrades?
Bushwalker76
Louisiana
9y
2.3L Ford Range
I have a 96 ext cab, 2.3L engine with a 5 spead stick. I'm starting a new job and the equipment I'll be running in the bed of the truck will weight approximately 950lbs. My GVWR IS 4740, on the sticker it has a section that says springs that list : GB. It doesn't list the curb weight of the truck, but Google tells me it's 3,300lbs? Both front and rear axel ratings are 2540 and 2550 lbs.
So I'm wondering if I should upgrade my suspension and if so what would be the best way to go, add a leaf? I don't know much about this.
My shocks are bad so those are getting replaced regardless. The truck has 95,000 miles on it
Thanks for anyone who can pitch in
Gumby13
Central Georgia
I know my 07 2.3 with the 5 speed is rated for 1260 pounds in the bed and 2660 pounds towing. I put a 5' long by 4' tall toolbox that weighed around 350 in the back, it squatted pretty good and the short wheelbase (single cab) made turns sketchy. Helper springs are the cheapest and you bolt them on and forget about them for the most part, airbags offer more control but cost more and have the possibility of the bags deteriorating over time.
Bushwalker76
Louisiana
9y
2.3L Ford Range
Thanks, from what you said I did a little research and I think I'm going to go with the helwig helper springs. Any recommendations on shock brands? AutoZone vs something on the internet?
Gumby13
Central Georgia
I'm running Gabriel max control shocks right now. Once they settle in the ride is amazing with and without a load, they take a some time settling though. Got them off RockAuto.com for a good price.
stsalvage
20
moreno Valley
i have 2 ranger
Ranger XLT exte
4.0 & 2.3
I'm the bearer of bad news but Remember that poor engine only has 100 hp an almost no torque. I have a 1996 2.3 5 speed extended cab with AC PS PB. Its time for you to find your self 1991--1994 with a 4.0 5 speed With the 8.8 ear end with positraction with a rear sway bar Gabrial High jacker air shocks and Put some Bilstein front shock on the front and that truck will corner like it's on Rails I can take my 1991 ford ranger 4.0 with the 5 speed and take a hard turn at 60 mph I can stay in the turn with a BMW and have it in 3rd gear with my 4.10 positraction 8.8 rear end with my sway back and stay with him me running a 215 70 15 BFG TA tire
Love the 4.0 if you have the 5 speed it will have the 8.8 rear end make sure it has a rear sway bar or you will Hate it
