Well I went to to check for just that. I been here long enough to to know thats what to look for
When I got there it had been parked about 3 hours. I turned to key to listen for the fuel pump...it was good. Started it up and it ran like a champ (as much as a chevy can). Let it run for a good half hour and no problems. However, after shutting it down there was a hissing noise above the left tire. I thought maybe the fuel system depressurizing. It lasted probably 15-20 seconds. Defenitely letting pressure out of somewhere (got quieter). Started it numerous times, no promblem. Drove it around the parking lot, and it drove and idled fine. But under hard throttle it would sputter badly, the car jerkin the whole way. It even died once but restarted on its own power I'm assuming because it was in drive and we were still movin. So the problem I think is its not gettin fuel. I got a fuel filter to swap out, but I think there may be a diff. problem. I plan to pull codes tomorrow.
Also the airbag light comes on sometimes out of nowhere, and under hard throttle the volts light cam on once (when it died). I checked the ground in the engine bay and the one I found on the block seemed fine. I need to clean it up a bit to be sure. Short to the fuel pump?
Any advice sure would be appreciated. Thanks
Oh, it has also blown the power lock fuse twice in about 2 months. Something funny going on electrical here.
