96 ranger ecu for svo
Chinolinoo
Charlotte, North Carolina
Mazda
Hey guys. I have a SVO motor from a 89' and I have a 96 Mazda B2300. Basically a ford ranger. Well I want to know if it was possible to use the 96 wiring harness and ecu for the svo motor. I have bought a tuning chip ( the sct 6600 eliminator) so i was curious if it was possible to use to the 96 wiring harness and the ecu on a 89' svo motor
Mr_Lee
Windham Centre, Ontario, Canada
Ford Ranger XLT
L33 5.3 LS
5"
245/45zr17 & 275/40zr17
Take the turbo rod and pistons. Drop them into the 1996 block. Tap an for an oil drain between cylinders 3/4. Get some 42lb greentop FoMoCo injectors. A 05+ Focus slot maf and a 98-01 2.5L ecu. Get a SCT tune on your chip and call it a day. You can use the 1996 harness on the SVO Block but to make it work you need a 1994 Cali cam sensor and a crank trigger and accessory brackets from a 90-94 Ranger 2.3L.
decipha
5
New Orleans, LA
bunches
too many
take your pick
decipha
the sct 6600 chip was a waste of money, could have bought an f3 moates chip for much cheaper
^^x2 what he said
I would recommend against the 42s though as they are only good for 180-200rwhp. Best bet is to go with siemens deka 80lb injectors from chris at poweraddersolutions (the only known vendor). They aren't much more price wise. And I would recommend going to the yard a finding a 2006 ranger ecu that only uses 1 coil pack instead of 2. Much more parameters in the ecu as well.
