97 ext cab, fw d44 & 9inch, foa 14" coilovers, on 38s....finally done, somewhat.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
my powerstroke is vacuum.
my ranger is hydro boost....gm setup from the donor of course. big tires stop better with hydro brakes ime. but hydro brakes can be cantankerous:icon_surprised:
most of the big boats and wagons in the 70's had boost as option or standard with lincolns etc....later non supercharged stangs have it...not because it is inferior.
took the engine, trans, rear, and braking setups from a 7x granada lincoln thing and installed it in a customer swap that netted positive cash before. the brakes were bad ass compared to my shitty ranger stuff at the time...
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
All diesels come with a vacuum pump, my 92 F350 7.3L was vacuum boost...Lincoln mark 7's are hydroboost with the 5.0L HO...Fact is, vacuum boosters provide up to 2000 psi of brake pressure, while the hydroboost setup have in excess of 3500 psi brake pressure...hydroboost units offer more braking with less pedal effort...
SVT
xkotyx
20
Waynesboro, VA
this is a really nice truck! keep it up man!
crazywhiteboy
May 2011 OTOTM Winner
clearlake, ca
thank you!!! looking into getting a 79 d60 and a 10.25 here pretty soon, gonna 3 link the front and double triangulate the rear soo keep reading, more to come hopefully pretty sooon!!!!:yahoo:
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
if you're going to make the effort to do the 3 link, why not make it a full 4 link?
crazywhiteboy
clearlake, ca
too tight under the front of a ranger to do a triangulated 4 link. 3 link with a trackbar under the front will be easy, double tri 4 link in the rear wont be bad either. the rear wont be done for a little while. gonna get the axles first, build them, get wheels/tires, 3 link the front run the leafs in the rear for a little, then 4 link the rear.
--weezl--
Law Enforcement
182
hell
Ok cool, just so you know, I saw a video on YouTube that showed a problem with the 3 link setup, which caused the axle to slide sideways if you had any axle wrap, if you were flexed to one side, but the other side didn't do it... Although I think the guy who made the video didn't make it right, his single upper link was directly above one of the lower links, causing it to be a-symmetrical... But I can't for the life of me Find the video now...
crazywhiteboy
clearlake, ca
i know exactly what video your talking about.
4.0B2
151
Walls, MS
4.0 v6
nice rig...
just read----i mean looked at all the pics in the thread. nice rig. i like it.
subscribed for more updates!
--weezl--
Law Enforcement
182
hell
yeah, somehow i have to imagine that the guy built the 3 link wrong... you wouldn't have it a-symetrical like that, would you?
mhughes165
9
302
SVT
?? never seen a mark 7 with the hydro boost setup, they run the same brake setup as the turbo coupes and the super coupes, its all electronic, electric pressure pump and all, no hydroboost to speak of
crazywhiteboy
clearlake, ca
yea i couldnt find the video either. actually i think his lowers were parallel, and upper was directly above one of the lowers. so his were symmetrical, which is what i think was wrong about his design. to be honest, i dont know much about link suspensions, but i was planning on using my existing extended radius arm mounts for my lowers, which would triangulate them a little bit. still not sure about the upper though. just need to do more research i guess. :icon_confused:
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
They came both ways, I was in the junkyard one day searching for a good 5.0L donor, and seen the hydroboost setup on it...
SVT
