'97 F350 PSD clutch recommendation, now build and whatnot saga :)
00t444e
217
Southern OH
Ranger ext cab
Let us know how loud it rattles.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
After you posted that I was curious since I hadn't done much research (other than seeing some 10 year old posts on random forums saying they were good...) and didn't see any complaints so I'm hoping for being reasonable :), it's not a daily driver and is straight piped after the turbo (exiting just behind the cab) so I'm not THAT worried, my main wants are the ability to feather it for trailer maneuvering or whatnot... now that I know the huge amount of slop in the geartrain was the counter shaft bearings and somewhat the hub of the Luk friction disc so it should be more pleasant to idle around campgrounds in first... I'm goin to lose my semi auto shifting ability though so I'll have to actually try to shift (with all the slop it would shift without clutch super easy)
Anywho, got the counter shaft bearings installed tonight, tomorrow I get to pull the two bearing races out of the case then clean that out and maybe check how much I have to shim the counter shaft so there's some preload... I have some shims... Might just make my goal of putting it in on Sunday...
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
I think all the micro metal particles make things harder to take apart... the output bearing race was STUCK, conveniently at a swap meet this morning I found a 3 jaw slide hammer for way cheaper than the OTC price which eventually got it out... the input shaft race was stuck but after destroying the oil baffle thing I was able to get my smaller slide hammer that I'd taken a 1/2-20 nut and welded a washer to it behind the race which was enough to get it out... the output bearing laughed at that setup last night...
I'm to cleanup then setting up for measuring for counter shaft shimming, as per "bulletproof garage" I want 2-4 thousandths preload
To sum up the special tools I've used:
-3 jaw pullers (one 8" puller modified to fit around synchro teeth)
-bearing separators (I think all 3 sizes HFT carries)
-20 ton press to save time (I'd never say anyone shouldn't have one of these, don't bother with the 12ton)
-3 jaw slide hammer puller (could probably get away with one with just a good strong hook attachment)
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
Trans is now in 1 piece, time to install the flywheel then clutch and so forth... already got the new carrier bearing in today and put in another transmission mount bolt (somehow was missing one...). Little behind schedule but not too bad, should be running Wednesday or Thursday night
bilbo
922
South Florida
2.3L
I've been busy with the yearly maintenance outage at work and missed all the updates. Looks like good progress! Thanks for the tools list and video references. It will come in handy when I get around to mine.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
The clutch itself is silent and works great, pretty grippy when warm starting in second it seems to want to start grabbing a little rough but not chattery like the old warn out Luk... with no slop in the countershaft it's a lot less surgy idling in first... the only dumb thing it does is the throw out bearing squeals against the fingers on the pressure plate when the clutch is released, don't know if this will go away once the bearing goes away or if I should take the dust shield off and put some grease at the tips of the fingers or what... it's annoying. The trans itself is way quieter than when the bearings were spinning, still whines but it's probably the wear on the input gear... noticed it was showing wear when I was putting it together but whatever... The clutch engages in the last little bit of pedal travel at the back just like the Rangers do, that's new, that old clutch was screwed... the pedal feel is fairly light from what I would have expected, not upset with the clutch so far...
It feels like there's a little air in the master or slave so I'm wondering if a bit of bleeding wouldn't help the throwout bearing issue...
Drove it to work today so there's about 70 miles on it now...
bilbo
922
South Florida
2.3L
When I put everything back together after replacing my clutch it would not release. The linkage rod between the pedal and the MC has a little plastic bushing where it connects to the pedal. Mine was shot and wouldn’t allow the pedal to actuate the pushrod in the MC far enough to disengage the new unworn clutch. Might be worth checking before messing around with bleeding it. Apparently it’s common and there are kits available to change it to a bolted on heim joint.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
I changed the pedal pivot bushings (was metal on metal too long... still some play) including the link on the pivot rod that goes to the master pushrod a few years ago when I put in the new "bled assembly" or whatever they call it with a new master, hose and slave... has a good bushing on the end of the pushrod on the slave, when I put it on before I even left the ears which made it convenient to pull the slave off since I just clipped them back on the bracket... when I first got it running it disengaged near the floor and I had to do the ol dump the pedal a handful of times to get it to feel right... probably need a new master I'd guess...
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
Now that I have around 300 miles on the thing I can give a better review, throwout bearing is chirping on the fingers pretty annoyingly but I didn't lube the lever pivot ball (was in the clean everything mode, forgot about that... will get to it when I change the fluid tonight or tomorrow...), other than that it is kinda grumbly when engaged in neutral when walking around it but NOWHERE NEAR what my buddies dual mass is on his Cummins... Drivability is good, really grippy but you can feather it...
Driving home apparently there's something going on with the rear passenger side brakes, locked up on me twice when engine braking (with mid brake pedal pressure) to a stop, once with a plume of tire smoke... so apparently I get to look into that... everything inside the drum is less than 2 years old so we'll see...
bilbo
922
South Florida
2.3L
Glad the clutch seems to be working.
I had that happen with the brakes a couple of times with the pass rear on mine, thankfully it never did lock up solid. But it would stick periodically, then permanently. I ended up cutting the parking brake cable and it popped free.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
Might as well make this more of a saga thread kinda like Eric's...
Got the thing in December of '13 if I remember right so right around christmas, it's green and came with a red canopy which got it dubbed as the "christmas tank" since it's huge and loud... and hence the one stencil I made up to paint the passenger fender (never got to the drivers side, the wally world paint is still there :)). Not long after that I moved and ended up with a big pickup bed camper so I pulled a spring up front and put F250 blocks in the back which dropped it like an inch in the front and 2 in the back. Since I was towing with the camper and cheap I made a home brew "super hitch" with a crossmember forward of the hitch (since I don't have a spare in the factory location) for the lower bar to push up on some and pinned for side to side, I've since gotten shorter campers so have cut that ridiculous hitch extension down to about 18" from almost 4'... At one point while towing the HPOP gave out 20 miles from home so I had to get a coworker to drag my trailer up to get it, drove it on and off the trailer with the starter (forgot to mention, before this I'd put on one of the fancy bigger '03 starters). A friend offered me a free engine so I couldn't pass it up, wish I hadn't sold it super cheap to another friend (stuff's expensive, he still got a screaming deal, I was kinda hard up at the time and wasn't as close as he is now). I've been fighting an issue where it runs hot when driving up hill for a long ways, the radiator was original from the looks of it so I got a fancy aluminum race radiator which helped some but not all (the old one was plugged inside and out so not wasted) so I got a replacement Borg Warner turbo ($700ish, wasn't too bad for a new name brand turbo) which did wonders but not enough...
I think that's the bulk of what I've done so here's some random pics in no apparent order:
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
My 2011 was similar but opposite on the color scheme. Red truck and dark green cap until I got a cap with a reenforced roof and a roof rack.
No members online now.
