97 O2 Heater fault
lordkyleofearth
Boerne, Tx
97/95 hybrid
FORD
2.3
Hey everyone.
I recently bought a 97 ranger 2.3 and have just finished rebuilding/installing the motor. All is working well except I keep getting a Bank 1 O2 heater circuit fault code. I traced the wiring down and had continuity between the upper and lower sensors on one wire, continuity to PCM (pin 93) on the downstream sensor, and no continuity from the upstream to PCM (pin 95). I ran a new wire to make that connection and still am getting the code.
The 13mpg super-rich conditions I am currently having are no fun. Any ideas on what is going on? Did I run the wiring incorrectly?
Thanks,
Kyle
3,614
bad sensor? did you just do continuity or did you do voltage drop? VD is much more accurate.
lordkyleofearth
Boerne, Tx
97/95 hybrid
FORD
2.3
Continuity test only. Both O2 sensors are new (Advance Auto, Bosch generic) and the heater fuse is new as well.
3,614
hmm, are you sure you wired them up right?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Are you sure its not a code for the downstream (after the cat) sensor?
lordkyleofearth
Boerne, Tx
97/95 hybrid
FORD
2.3
The code is P0135.
One sensor was prewired, the other was the one that you wire in yourself. I followed the directions and the double checked myself prior to install.
Since they are on a common circuit, I suspect the fault could be with either sensor or any of the wiring, right?
lordkyleofearth
Boerne, Tx
97/95 hybrid
FORD
2.3
I think I am going to chase the wiring again tomorrow. To be clear:
I should have continuity (with the sensors installed and wired correctly) between pins 93 and 95 on the PCM correct?
Sensors removed, the harness should give continuity from #95 to the upper sensor (arbitrarily, wire A). Upper sensor to the lower sensor (wire B) and then lower sensor to PCM #93 (wire C). One of the wires (A or C) will have a quick detour to the fuse box. Right?
And if I see no continuity with the sensors installed, but I do have continuity along each leg (sensors removed) then I can conclude that the generic sensor is wired wring. Does that sound correct?
3,614
sounds right. Don't have a diagram in front of me, but that sounds about right.
