98 and up 3.0L trans
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
The difference bbetween a 1998-up 3.0 trans and a 1995-97 trans is almost trivial.
The difference is that the stub lever is different to accomodate the
later style shift lever.
the 1988-97 shift lever uses a cotter bolt that runs fore-aft on the
passenger side of the lever
on the 1998-up lever the retaining cotter bolt runs side to side,
because the casting at the base of the lever is positioned to put
the shift knob about an inch or inch and a quarter to the rear...
If you get the lever with the trans use the later lever.
If you don't get the lever I've got a couple of the later levers laying around
OR you can simply swap your stub lever in and use your current shift lever.
AD
funkingonutz
Enfield CT/LongmeadowMA/AgawamMA
3.slow
ok cool...so I can just use my current shift lever on my blown 95 trans...and put it on the 98 trans??? correct??
