98 cobra upgrade /93 ranger 2/wd
smccatv
Southwest Ohio
Ranger xlt
I can get some ,98 cobra front and rear disc brakes. The rear bracket was cut for a Fox upgrade. 16 or 17" rims I assume for the large rotors. Depending on rims how much spacing will I need? Like to go with Mustang rims.
Rangeritus
16
Desoto, MO
Ive got mustang rear brakes on my rwd ranger. But they are just gt, smaller ones with mustang 17" wheels plenty of room. Not sure if 16's are big enough for the cobras but 17's should definately fit
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
649
Central Indiana
17" minimum wheel required for the 13" Cobra front rotors.
You'll need a plan for front hubs because the Ranger's stock hubs are integrated into the rotors. The kits that used to be sold took a Ranger rotor and machined the rotor part off until it would fit into the Cobra rotor hat. There might be some pics somewhere on the internet to help explain a little better.
You'll need a custom caliper bracket in the front to move the caliper away from the hub enough to fit the larger rotors. Do the 93's have single piston calipers? It's definitely worth a caliper upgrade if they do, but that might require newer Ibeams.
If you're willing to do an I beam swap, I'd suggest the ATS brake option over the Cobra stuff. They're better calipers than the Cobras:
don4331
1,352
Calgary, AB
5.3
'93 have the single piston/"slide" calipers. So, @smccatv really wants to start by upgrading his Ranger's knuckles to '95-'95 ones to get bolt in calipers (doesn't require newer i-beams, but you would want to replace ball joints while you had it apart). Then integrating adapter between knuckle and caliper becomes a bolt in process (An adapter for "slide" calipers would be a work of art though).
I've done the machining on hub/adapter myself, but due to product liability reasons, I won't commercially do it. And my adapter was hogged out of a single block of steel as I don't trust aluminium on brakes where the original design wasn't for that material. Saving a pound wasn't worth it on 2,500lb truck.​
@smccatv You probably want to run spacers with most (all) Mustang rims, so the bearing cap doesn't interfere with the rim center/the offset is correct - you can see @Rangeritus is. (Ranger rims are 0-12mm offset, Mustangs are 30-40mm).
Rangeritus
16
Desoto, MO
Yes had to add the spacers so the mustang wheel centercaps cleared the spindles
