'98 Light Adjustment on Driver's Door
conyers73
Cave City, AR.
ranger
2.5 4 cylinder
How do you adjust the door to make the interior light work for the driver's door on a 98 Ranger XL ? The passenger door works fine-Thanks.
XLTsplash
160
CA
2.3L
Try spraying WD40 in the latch, Give it a good soaking. The switch is mounted in the lower part of the latch. Dirt can cause the switch pin to stick. Spray the WD40 in then open and close the door a few times and spray the latch again, replete this a few times. If it doesn't work you may need to replace the switch.
conyers73
Cave City, AR.
ranger
2.5 4 cylinder
Thanks XLT Splash, I'll certainly try that.
