98 ta 95 cab swap
Ranger Dave
4
Newbury NH
i bought a 98 reg cab 2wd long bed 4.0 for the engine(tago in my 95),but the truck is in really good shape cept the frame i saw where someone did a xtxa cab swap.sooo, i was thinking about swappin cab,engine and all the wiring from the 98 onto my 95.i know the cab is a lil longer on the 98,no big deal. is the cab a direct bolt on?? im guessin the rear cab mount might be back a lil further back. do any of the mounts line up? the 98 is a automatic, 95 is a 5spd, anyone know if the brake/clutch bracket will swap over to the 98.....and yes the 2.9 is still runnin in the 95 :)
53969
53965
53966
franklin2
1,790
Virginia
I will be curious to see what someone says also. On the full size trucks you can't swap a extended cab onto a regular cab frame unless you use a body lift at the same time. On the full size trucks there is a frame kick-up behind the cab. The frame kick-up is further back on a extended cab frame to give it clearance. But people have used body lifts to lift the extended cab up high enough to clear the regular cab frame kick-up. Then of course you have wheel base and bed length issues to deal with.
Don't know if this is true on the rangers. You can go out and take a look if you are close to both trucks.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,657
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I removed one of your threads... it was really the same post. No need to have two separate threads asking the same questions.
I don't have the answers you're looking for... but I'm sure someone will come along with some of the information you want.
