99 5.0 Explorer fuel pump floor cutting template/location.
marauderx
Baton Rouge, La
FORD
2.3T
I am looking at purchasing a 1999 explorer with 170K and it has been sitting for 3 years. I hate dropping tanks, I would rather cut the floor, and fab a cover plate Like Mercedes-Benz does. Does anyone have pictures and or measurements to do that? I am going to purchase the vehicle, and I cannot get the pump to spin. I pulled the cover off a relay, and manually actuated it, and nothing, It is making a connection, as per my power probe, but no spin. any pictures or landmarks would be great.Thanks!
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
probably you toob stuff on that.
have a gawk under there and get to it.
i know the 90's units did not have holes for it. some do though in the cars and i think the escapes.
i do the bronco 2's that way. the explorer wont be as easy...pretty sure it is under the seat too so compound cutting through supports will probably be part of the deal.
1/2 in drill bit and a nibbler to do most of the work safe and make a window big enough to keep ya from wrecking stuff......and a scroll saw or body saw should make quick work of it if there are supports to go through..
fastpakr
2,834
Roanoke, VA
There has definitely been discussion at length about how and where to cut at explorerforum.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
pulling the tank on an Explorer is WAY THE HECK easier than a Ranger, seriously there are two bolts in the front and one in the rear holding the tank in other than the fuel filler neck and fuel lines. Ok, I'll admit when I got this thing the fuel tank skid plate was missing but I don't think that adds too much to the process, which reminds me I should grab one of those from a junkyard...
I say this from experience, I did a fuel pump on my '91 Explorer without jacking the rig up, and when I put the manual transfer case in my '00 Explorer I had to pull the tank loose and modify the front mount bracket, on that one I had the front on ramps and the rear on jack stands which made it easier but still not bad, did it again when the trans went out again a few months ago... I don't think the fuel pump I changed took more than an afternoon.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i know i probably dont have to mention this.
dont use a grinder.:thefinger:
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
plasma cutter or torch is obviously the best option :) Steel tank on the Explorer though, so it's a little more hardy...
marauderx
Baton Rouge, La
FORD
2.3T
Yeah, Probably going to drop the tank, would love to use an ATV jack to lower it, but I do not have room to store one when I am done...
