Leigh
- Jul 20, 2011
- 0
- Ford Ranger 2WD
99 Ranger bought used, so no history.
AC/ blower works, but no heat. With heater on "Full' there is absolutely no evidence of warm air, & since AC compressor continues to be engaged, the air actually feels cooler than outside ambient.
Trouble shooting so far:
(1) Upper radiator hose relatively hot/ Temp gauge mid-way/Normal suggesting thermostat, & Water-pump OK.
(2) Inboard heater hose (Inlet, I assume) is hot either side of 4-way control valve.
Outboard heater hose is only barely warm at outlet from heater core.
I flushed the Heater core until running clear in both directions, but made no difference.
(3) The 4-way Heater control valve has the AC Vacuum line disconnected, but it's my understanding that this shuts hot coolant flow to the core with Max AC On.
It's spring loaded in the Open position, so shouldn't effect heater ops.
(4) I removed the Blend Door motor, and checked that it operates OK.
The motor shaft, and the receptacle it engages with show no signs of damage, or distortion.
I'm not sure how to positively confirm that the Blend door is working properly, as I can't see it, but, from what I've read on the matter, the results of the steps I've performed indicate that the Blend door is OK.
I'm not sure where to go next with this? I could try replacing the Control Valve, but I hate to throw parts/money at the problem without a reasonable conclusion of what the cause is.
Any help/suggestions would be most appreciated.
LW
LW
