NoHandlebars
- May 16, 2015
- 0
- Ranger
Ok here is the deal. I have completely ran out of ideas.
So last year my air worked just fine, ok. This year I turn the A/C on from inside the truck and, well nothing. We get the auto kick on and off of the compressor when you start the truck, but that is it.
So we have tried jumping the high, and low pressure sensors, both together and individually. We checked all the wires and the correct power is getting to them. It has freon in it. We jumped the compressor with the air turned "on" in the truck before blowing a fuse and the clutch engaged while being jumped, and when we checked inside the truck it was blowing cold AC no problem. So we know the compressor works. The wires to the compressor also have power going to them. We have literally jumped/tried everything we can think of, we even changed the orifice filter.
Has anyone else had this problem? It has me and 3 other people totally lost here.
Basically. The air works if I jump the compressor. If I turn it on normally, it will not kick on. All wires, connections, etc. have been checked and work.
