A couple full width ?'s
brickhouse7
Im trying to finish up everything on my 93 ranger, full width 44 and 9". I've got a coulpe of question, what are you guys running for steering? I know cross over is one option that im considering but if not what tie rod are you using with the hole in it for the drag link, also Im riding the 2.3 2wd for awhile so is there a u joint from the stock drive shaft to the 9" yoke i can get. The standard "bastard" joint that everyone carrys isnt right. i need one with ranger caps on both sides and one side with ranger width and the other with f150 width. Any help??? Ill try to get some pics of the build up tomorrow!
alaskan155
6
washington
FORD
7.3l/4.0l
ford motorsports sells the joint you need
Junk Collector
Truck of Month
4,870
Rapid City SD
Easiest way to get the u-joint is to bring the driveshaft to a driveshaft shop and have them get a joint for you, then buy 3-4 of them so you've got spares.
For steering, I'm not really sure. All of the guys around here have built their steering out of DOM and used heims instead of TREs.
Hondafreak08
Dayton, ohio
www.partsmike.com for steering.... great guy to workwith.. one day turnarround... havnt got to driveshafts... full width swap kinda seems like u have to jump arround to get it right in order..
