a4ld argggggg.
alaskan155
6
washington
FORD
7.3l/4.0l
well i bought this 94 explorer(230k miles1 owner kept stock)/ rebuilt trans in the last 4 years), its driving me nuts.
everytime the converter locks up in 3rd or OD on the highway(usually around 50-60 it starts) it get a nasty vibration under the seat and i can't figure it out. as soon as i give it gas and drop a gear or put it in regular it seams normal.
ive rebuilt the rear driveshaft(new u-joints/greased slipjoint)
Ive install new plugs, wires, and a known working coil pack
water pump
checked harmonic balancer seemed to be in good condition
tires are off of ranger and had no vibration issues when i pulled them.
installed lift shackles but pinion angle seams fine.
took slack out of throttle cable / adjusted kickdown
ecu temp sensor
thermostat
cleaned MAF/checked for vacumn leaks
tags where expired when i looked at it(2015) so it was sitting the last 2 years atleast before i got it.
im just at a loss, are these a4ld just that crappy and they can't handle 35s on 3.73s gears?
this thing also feels gutless compared to my 2000 ranger(will barely do 70)mph with the same 4.0 besides the slight hesitation right past idle she runs smooth but i have to floor it just to get her up to highway speed.
but i have the same setup as the ranger had 3" body 2" suspension and 35s
only difference between the 2
3.73(explorer) vs 4.10s(ranger)
5r55e vs a4ld
miles 153k(R) vs 230k(E)
so any thoughts on this a4ld? or should i be planning to yank it soon and swap in the 5r55e(would mean converting the X to OBDII(which i like better for diagnostics) in or just drive it in regular D tell it dies?
rusty ol ranger
2.9 Mafia-Don
7,658
Michigan
177 CID
Honestly, id be taking a hard look at the torque converter.
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Get a tube of this and add to the fluid. May take 30 or more miles to work.
You are describing a torque converter shudder to a T.
Good luck.
alaskan155
6
washington
FORD
7.3l/4.0l
Ive added 2, im starting to think its in the engine, if i put it in 2nd and try to go up the driveway it bogs down and i can somewhat replicate the vibration, im starting to think the compression is down on one of the cylinders..i checked out the egr and its good, the one in my 2000 runs a ton better(no bogging or engine vibration so im at a loss.
alaskan155
6
washington
FORD
7.3l/4.0l
fixed it, number 3 injector was dead(no fuel)..... after 2 weeks of messing with it my neighbor caught it in 5 mins(use to work in a shop)...
never had 1 fail before, oh well i have some ev6 injectors i swapped in from my 2000 ranger and she is running like a top now...
thank-you for the help, i appreciate it,
rangerenthiusiast
Hudson Valley, NY
Wish I’d seen your thread earlier. I just picked up a ’92 Ranger a few weeks ago and had similar vibration issues. Tested the coil pack, wires, plugs, threw some Seafood in the tank, changed the fuel filter, etc. Then I found a rebuilt set of Bosch injectors on eBay for $67. Figured there was no way I could go wrong at that price. Popped them in and it ran like a different truck. The old ones were disgusting and I couldn’t believe that the truck had even been able to idle with them in.
By the way, the 4.0 engine is an OHV version (rated at 160 HP) up until 2000. But starting in ’97 (Ford Explorer), they introduced an SOHC version that bumped the HP up to 210 (anyone who knows otherwise, please feel free to correct me here). By 2000, the OHV 4.0 was discontinued. So that may account for the difference you’re noticing in power. Details here: https://en.wikipedia.org/wiki/Ford_Cologne_V6_engine#4.0
rangerenthiusiast
Hudson Valley, NY
Good luck.
Hey, Transman. I recently picked up a ’92 Ranger Custom with a 4.0 (supposedly with 81k original miles) and A4LD trans. I’m going to be changing the fluid and filter in the trans soon. Would it be a good idea to put a tube of this in while I’m at it?
Thanks!
Transman304
43
Morgantown WV
Chrysler PT
2.4
I would recommend saving as much of the old fluid you can just in case you find a lot of debris in the pan. And put it back in with new filter and top off with new fluid. If pan looks decent put new fluid in and add a bottle of Lubeguard Platinum.
rangerenthiusiast
Hudson Valley, NY
Okay, now I’m confused. Why would anyone ever put old, crappy fluid back into a transmission? :icon_confused:
Also, Lubeguard Platinum instead of the shudder fix, eh? Is that an additive that just helps protects against future shuddering? Is it worth it, do you think?
Thanks. :icon_thumby:
alaskan155
6
washington
FORD
7.3l/4.0l
yeah both my 2000 and 1994 are the ohvs, never messed with the SOHC.
ive have found some parts interchange while others(like certain sensors)dont between the years.
2000 was the last year for the OHV, 2001 ranger got the SOHC, 99/2000 where a test bed for the 5r55e before putting the higher hp SOHC in front of it in 2001.
in the explores the SOHC was a optional motor. so the produced the OHV and SOHC side by side, so you could have either or in a explorer(along with a 5.0)
